Ajujdeorbiuser
Apr 24, 2024Aspirant
Satellite failed latest update
My satellite failed latest autoupdate and the device is now blinking red power led. What to do?
Apr 24, 2024Guru - Experienced User
Pressing the reset button in back for 15 seconds then release doesn't clear the RED LED in back?
Last resort would be to do a 30-30-30 reset on the RBS to see.
If this fails then the RBS probably needs to be replaced.
Ajujdeorbiuser
Hello Furry, thank you the reply.
I tried Tftp method using windows cmd and. Tftp64 software. Both method failed.
But i successfully recovered the satellite by using Nmrflash utility. I used latest V.31 to recover. My satellite now connected to router and network. My home devices are connecting to this satellite. However the version showing is still V.21. From Orbi app and web console. I checked for update and shows no new update. My other device at v.31 and this one is still on v.21. Why is it like this? I am afraid to manually update. If the firmware again corrupted, ?
