jonmell
Aug 25, 2021Guide
Satellite issue on orbi 6
Hi - I have an Orbi 6 RBR850 and two RBS850 satellites. All working fine for a year or so then had to do a factory reset of the entire system to fix a password issue. Now one satellite is wor...
- Aug 25, 2021
Does the status on the RBS web page report GOOD or Config Sync or Out of Sync for either RBS?
Id you factory reset the RBS after you manually reloaded FW?
You might try a reset on the RBS. When the Front LED pulsates WHITE, turn them OFF. Go to the RBRs web page and select Remove.Reboot the RBR then power ON the RBS. I would hit the sync button on the RBS then RBR and see if the re-sync will take. When the RBS front LED turns BLUE then OFF, see if the web page is accessible using the RBRs web log in info.
Do you have any special characters in the admin password?
jonmell
Aug 25, 2021Guide
Thanks for helping out.
So I can get to both the problem RBS and the behaving RBS via the web as far as the login screen. But the web password I set for the RBR (which works on the RBR IP address) don't work for either of them. Neither do the default admin/password.
On the RBR web page both RBS look good/the same.
The front LED of the problem RBS did go blue (solid) as it is supposed to during setup after the factory reset
jonmell
Aug 25, 2021Guide
RBR is on V3.2.18.1 (as are/were both RBS)
Just managed to manually reupload 3.2.18.1 to the problem satellite but no good
- FURRYe38Aug 25, 2021Guru - Experienced User
- jonmellAug 25, 2021Guide
Looks like that did it!
Key was rebooting the RBR in between removing/factory reset of the RBS before adding it back. Bizarrely it still remembered the new satellite name but I'm taking the W.
Thanks for the invaluable help!
Please mark your thread as solved so others will know.
Enjoy.
