BuzzH
Dec 21, 2022Aspirant
Satellite lost synch and cannot regain
I've have my Orbi 960 and two satellites up and running for almost a year with no issues. This morning, I noticed poor connectivity in the kitchen and after some troubleshooting on the routers home p...
- Dec 22, 2022
Thank you to you and the others who replied. After trying the many solutions provided here, I finally decided to one more time factory reset the errant satellite late last night. For reasons unknown to me, even though I did nothing new, the satellite booted up, found the router, and turned blue. That had happened several times before, but this time, it finally displayed in the web browser and the Orbi app as a working satellite.
All seems well. I really appreciate the time you and others spent with me.
Dec 21, 2022Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
- BuzzHDec 21, 2022Aspirant
I've done those steps but will try again.
My firmware shows current as V6.3.7.5 on the router and the one satellite that still works. Can't see the other one obviously.
I have a 3100 sf home with an unfinished basement where the router is connected to the modem. I am Cat 6 hardwired for the backhaul, so the distance should not really matter (and hasn't for the past year), but it's probably 40-50' straight line through a floor.- FURRYe38Dec 21, 2022Guru - Experienced User
Wondering if the one RBS didn't update properly?
Are both RBS connected wired to the RBR?
I'm wondering that myself. Is there a way to check/fix that? Do you know when the most recent firmware came out? Mine is set to autoupdate, and this problem just started this morning.
