BuzzH
Dec 21, 2022Aspirant
Satellite lost synch and cannot regain
I've have my Orbi 960 and two satellites up and running for almost a year with no issues. This morning, I noticed poor connectivity in the kitchen and after some troubleshooting on the routers home p...
- Dec 22, 2022
Thank you to you and the others who replied. After trying the many solutions provided here, I finally decided to one more time factory reset the errant satellite late last night. For reasons unknown to me, even though I did nothing new, the satellite booted up, found the router, and turned blue. That had happened several times before, but this time, it finally displayed in the web browser and the Orbi app as a working satellite.
All seems well. I really appreciate the time you and others spent with me.
Dec 21, 2022Guru - Experienced User
Lets turn down the power as well:
Advanced Tab/Advanced Settings/Wireless Settings
BuzzH
Dec 22, 2022Aspirant
- FURRYe38Dec 22, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-SystemI recommend disabling Auto Update on the RBR.
Enjoy. 📡
