arnoldzw's avatar
arnoldzw
Satellite not available app
Dear All, Have a question about a setup. 1x router RBR850, 2x satellite RBS850. I have an ISP where the modem unfortunately cannot be used in bridge mode, so it also has the router function. ...
  • arnoldzw's avatar
    arnoldzw
    Jul 23, 2024
    Thanks,
    I have ordered an additional sattelite, and placed that on the former location of the router.
    The original router is placed nearby the switch and you`re solution worked:
    • Router connected to the switch.
    • Satellites connected from the patch panel directly to LAN ports on the RBR850 (not connected to the swtich)
