arnoldzw
Jul 14, 2024Aspirant
Satellite not available app
Dear All, Have a question about a setup. 1x router RBR850, 2x satellite RBS850. I have an ISP where the modem unfortunately cannot be used in bridge mode, so it also has the router function. ...
- Jul 23, 2024
Thanks,
I have ordered an additional sattelite, and placed that on the former location of the router.
The original router is placed nearby the switch and you`re solution worked:
- Router connected to the switch.
- Satellites connected from the patch panel directly to LAN ports on the RBR850 (not connected to the swtich)
arnoldzw
Jul 23, 2024Aspirant
Thanks,
Jul 26, 2024Guru - Experienced User
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
