Guru0006
Mar 11, 2022Aspirant
Satellite poor speed RB960
Have talked to tech support for 2 weeks. I initially was getting 560 MBPS speed wirelessly at router and still am consistently. The satellite which is just 15 feet away in my bedroom I was getting 460...
- Oct 13, 2023
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy the new system. I am too. 📡
Mar 11, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Be aware that some WiFi devices may top out at lower speeds as they are limited by there MIMO configuration. 2x2 usually cap at 300-500Mpbs on 5Ghz AC. AX may see around 700Mpbs. 6Ghz will be the same. 4x4 MIMO devices can see over 900Mpbs on 5Ghz AC and AX.
Also distances from either RBR or RBS will impact speeds as well. Nearest will be good speeds, farther, speeds will drop. Nature of the wifi beast.
5 and 6Ghz signals are effected by building materials as well.
