Guru0006
Mar 11, 2022Aspirant
Satellite poor speed RB960
Have talked to tech support for 2 weeks. I initially was getting 560 MBPS speed wirelessly at router and still am consistently. The satellite which is just 15 feet away in my bedroom I was getting 460...
- Oct 13, 2023
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy the new system. I am too. 📡
Guru0006
Oct 13, 2023Aspirant
Yes once I swapped it out and tweaked position of satellites relative to the router speeds went up and worked well since. Now I tore it all down boxed it back up and have setup my new RBE973 setup. Haven't decided what to do with my previous setup but new one has increased speeds even more over the 963 setup. I'm ecstatic with my bday gift to myself.
Oct 13, 2023Guru - Experienced User
