Startribe
May 15, 2021Follower
Satellite RBS750 Can't hard wire ethernet from Satellite to my MacBook for faster zooms
I have a Orbi Model RBS750 satellite unit. I want to use an ethernet cable to plug my computer directly into this satellite to get better quality on zoom calls. There are two plug ports on the ba...
May 15, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
You can connect ethernet devices to the back of RBS. Ensure the cable is of good quality. Try a different wired device to compare.
Possible the RBS is faulty if other wired devices don't connect.
Thank you.
