FilGov
Jan 24, 2021Aspirant
Satellite stopped doing 2.4 GHz
1 of my 2 RBS850 satellites suddenly stopped accepting 2.4 GHz connections, only 5 GHz works.
Jan 24, 2021Guru - Experienced User
What 2.4Ghz devices are you using?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
