FilGov
Jan 24, 2021Aspirant
Satellite stopped doing 2.4 GHz
1 of my 2 RBS850 satellites suddenly stopped accepting 2.4 GHz connections, only 5 GHz works.
Jan 24, 2021Guru - Experienced User
What 2.4Ghz devices are you using?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
FilGov
Jan 25, 2021Aspirant
Mostly Rowenta Intense Pure Air Connect XL air purifiers and TP-Link HS110 smart Wi-Fi plugs.
V3.2.16.22_1.4.9.
MEO FiberGateway GR241AG.
~271 m2.
~5 m.
Auto. Yes. Done, issue persists.
Yes. 1.
- FURRYe38Jan 25, 2021Guru - Experienced User
FilGov wrote:Mostly Rowenta Intense Pure Air Connect XL air purifiers and TP-Link HS110 smart Wi-Fi plugs.
V3.2.16.22_1.4.9.
Your ONT has built in router and wifi already.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop~271 m2.
~5 m.
Yes. 1.
- FilGovJan 26, 2021Aspirant
FURRYe38 wrote:Your ONT has built in router and wifi already.
I know, Wi-Fi is disabled and Orbi is in AP mode.
https://kb.netgear.com/30187/How-to-fix-issues-with-Double-NATNot the issue, router is in AP mode and other satellite works fine.
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.Pointless, other satellite works fine.
Already did.
Not the issue, different floors and other satellite works fine in same spot.
