SteenSN
Oct 02, 2021Tutor
Satellite wifi flickers off several times per day, wired devices fine.
SETUP: CBK752 — Orbi WiFi 6 DOCSIS 3.1 Mesh WiFi System with Built-in Cable Modem (1) Orbi Cable Modem Router (CBR750) + (1) Orbi Satellite (RBS750) Setup in a 3200 Sq Ft House, satellite and route...
Oct 05, 2021Guru - Experienced User
Ok, I would try a factory reset on the RBS and power it off for 5 minutes. I would remove the RBS from the RBRs web page after the RBS is turned OFF. Then power ON the RBS and resync it using wireless first. Use the sync button on the RBS then RBR. Wait for the front LED to turn BLUE then OFF. After then connect the RBS via ethernet to the RBR.
What channels are you using on the CBR?
Has the system been factory reset and setup from scratch since last update?
