frozenwaste
Jun 27, 2024Aspirant
Satellite wired connection
Hi, I have ordered the Orbi WiFi 6 mesh system, arrives tomorrow. I'm wondering the best way for installing. House is an large old farmhouse with thick sold brick walls, distance from hom...
frozenwaste
Thanks for the links.
I think the ethernet backhaul, the bottom of the 3 images connected via hub, is the way to go for my house!
Jun 27, 2024Guru - Experienced User
Just be sure to get a non-managed switch. You'll be fine.
Good Luck.
