popechild2
Jun 27, 2023Guide
Satellite won't connect. Hardware problem?
Hoping I haven't overlooked advice or a solution in the forums, but searches haven't turned up anything useful so far, so I appreciate your help. I have a router and two satellites (AX6000). Has ...
popechild2
Jun 28, 2023Guide
Thanks. That’s good to know. So nothing else obvious you can think of I would be doing wrong in setting the network settings when it’s showing the cables as disconnected? There may not be, just trying to make sure before agreeing with NG to pay for a support plan if it ends up not being a hardware issue.
Jun 28, 2023Guru - Experienced User
IF the RBR was working the cable would show connected, just not having an IP address or would time out and the connected PC would set a self assigned IP address of 169. If the status shows cable disconnected when connected to the back of the RBS, would be that the port or something handling the port connection has failed or the FW/HWsystem on the RBS has failed.
- popechild2Jun 29, 2023GuideTo bring closure to this, I actually got a voicemail today from the csr apologizing for lying to me about the paid support options. When I called back, I spoke to someone willing to actually troubleshoot with me and they concurred that it’s a hardware problem. They’re sending a replacement. Thanks for the help!
- FURRYe38Jun 30, 2023Guru - Experienced User
Glad they stepped up. Let us know how the new unit works out for you.
