lb24569
May 13, 2022Aspirant
Satellites and network switches not working on new Fibre Setup
Hi All, I've recently switched from cable broadband (Virgin Media) to FTTP (Fibrehop UK) and I'm having problems getting the new connection to work with my RBK352 Router + Satellite. My setup i...
May 13, 2022Guru - Experienced User
so it works connected to the router? Just the satellites aren't working?
What switch are they running through?
lb24569
The satellites and my other network switches connected to the router. (they all worked fine with my previous ISP)
- plemansMay 13, 2022Guru - Experienced User
What switches are they?
- lb24569May 13, 2022Aspirant
They are netgear wac104 switches. Which I'm currently using now (working fine) with the ISP supplied router instead of the Orbi.
- Mikey94025May 13, 2022Hero
lb24569 wrote:They are netgear wac104 switches. Which I'm currently using now (working fine) with the ISP supplied router instead of the Orbi.
Netgear WAC104 seems to be a wireless access point, not a simple network switch. Are you sure?
The Orbi satellites are very sensitive to how they are wired to the router and its best to use certain unmanaged switches. Many managed switches have broken the Orbi mesh. This is why we need to know what switches you're using and how they are wired into your network.
Another experiment you can try is to setup your Orbi satellites wireless, just as a test, see if it works, without using your wired backhaul and existing switches.
