scramblur
Jan 13, 2025Aspirant
Satellites are not showing devices connected
I'm using an RBR850 and have one RBS850 and two RBS750s, but devices only show up on my 800 series units. I know the RBS750s are making a difference because as soon as I unplug them, I lose respecti...
CrimpOn
Jan 13, 2025Guru - Experienced User
What firmware is installed on each of these devices (router, 850 and 750 satellites)?
How are the 750 satellites connected to the router? (default WiFi connection or 'wired'?)
- scramblurJan 13, 2025Aspirant
The RBR850 is v4.6.9.11
The RBS850 is v4.6.9.11
The RBS750s are running v 7.2.6.31
I have one satellite hard wired the others wireless.
- FURRYe38Jan 13, 2025Guru - Experienced User
The RBR and ALL RBS need to be on same FW version level.
- CrimpOnJan 13, 2025Guru - Experienced User
FURRYe38 is correct. For some (unknown) reason, the AX series of Orbis struggle when the router and satellite are on different firmware releases. Connected devices do not seem to be affected because the Orbi router creates one "Layer 2" network and data packets can flow wherever they need to. What seems to be most affected is the ability of the router to display information about what is connected to the satellites.
There are basically two choices:
- Manually install firmware v4.6.9.11 on the two RBS750 satellites.
- Upgrade the 850 units to v7.2.6.31 (satellites first, then router).
This is not a trivial decision. The "7" firmware introduced a new WiFi network: the "IoT" network, which customers had been asking for (good), but the forum has a number of very long discussions where users are not happy with v7.2.6.31 and have "gone back" to v7.2.6.21 (bad). Frankly, it's a mess.
Or, you can leave it alone and try to ignore not knowing exactly what is connected.
