netblokeusa
May 18, 2021Aspirant
Satellites dropping WIfi constantly. RBR750
I have gone through these forums looking for a solution....was sugegsted reposting in this sub forum... So I use Xfinity. My Cable modem is an Arris SB8200. Orbi Router is RBR750 (purchased thr...
May 24, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Traffic Meter.
Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
