cshaver
Sep 03, 2024Aspirant
Sattelite keeps dropping
I recently installed a mesh system with 1 RBR750 and 2 RBS350s. The Base and one of the Satellites work great. The 2nd Satellite won't maintain a connection (it connects, then drops, then connects ...
- Sep 03, 2024
Need to downgrade the RBR back to v4 FW. v7 FW is NOT compatible with v4 FW and NG isn't releasing any v7 FW for the RBS350s.
cshaver
Sep 04, 2024Aspirant
That solved it!
I also had to drop the IOT since that was only supported in 7.x but looks like my network is stable again.
Thanks!
Sep 04, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
