xduyck
Jun 18, 2020Follower
Sattelite question
Hi, do I need to connect the sattelite trough an RJ45 as well or does the sattelte box connects to the router trough the wifi ?
1 Reply
- Chuck_MMentor
Satellites backhaul to the router in one of two methods.... wired or wirelessly.
Wirelessly is most certainly the more common method -- and typically works right out of the box.
Orbi has dedicated internal radios to perform this high-speed backhaul.
You can, however, use a wired connection, based on your own scenario (perhaps the wireless backhaul cannot reach the satellite).
