Ramboost2000
Jun 21, 2020Aspirant
Sattelites seem to lose wifi settings after change
I have an RBR850 router and two RBS850 sattelites on a wired backhaul. After I changed some of the advanced wifi settings (lowering the 2.4 ghz transfit power) it seems like the two sattelite are not...
- Jun 24, 2020
After a lot of trial and error, I managed somehow to get the sattelites to sync properly witht he router after I changed the operation mode from AP to Router. I then changed back and evyrthing works fine. Strange, but it works now.
/Ramboost
Ramboost2000
Jun 24, 2020Aspirant
/Ramboost
Jun 24, 2020Guru - Experienced User
Glad you got it synced. I just moved back from AP mode to router myself. :smileywink:
Mark your thread as solves so others will know.
Enjoy, :smileywink:
