KMDonlon
Sep 17, 2020Virtuoso
Saving new device icons fails?
With firmware v. 3.2.16.6_1.4.4 I noticed when I do a complete set up from scratch I am unable to get an icon to save if I change it from the default wireless device icon. For example, my Skybell H...
Sep 18, 2020Guru - Experienced User
I would file a support ticket and let NG know about this.
Thank you.
For example, my Skybell HD will allow the name and manufacturer to change and save but when I try to set the icon to "doorbell" it will not save in the web GUI. Also my thermostat acts the same way, not able to save with the thermostat icon.
Oddly enough, if I downgrade the firmware to v. 3.2.15.32_1.3.25 there are no issues.
A bug introduced in v. 3.2.16.6_1.4.4 it appears. Very annoying!!
