KMDonlon
Sep 17, 2020Virtuoso
Saving new device icons fails?
With firmware v. 3.2.16.6_1.4.4 I noticed when I do a complete set up from scratch I am unable to get an icon to save if I change it from the default wireless device icon. For example, my Skybell H...
dtay
Sep 24, 2020Luminary
For example, my Skybell HD will allow the name and manufacturer to change and save but when I try to set the icon to "doorbell" it will not save in the web GUI. Also my thermostat acts the same way, not able to save with the thermostat icon.
Oddly enough, if I downgrade the firmware to v. 3.2.15.32_1.3.25 there are no issues.
A bug introduced in v. 3.2.16.6_1.4.4 it appears. Very annoying!!
I actually have a ticket opened with support about this exact same issuse (device icons not saving correctly either on the Android app or on the web GUI) but sadly it's not progressing anywhere in terms of a resolution. The particular tech that I've been working with isn't responsive and could only come up with responses such as "reinstall the app", "reset the orbi", "downgrade your app", "reboot". SMH.
I've even sent screen video caps showing me changing the icon, say, of my Ring Doorbell which it thinks is a laptop or computer, to a ring doorbell, and but it doesn't stick.
Mstrbig
Sep 24, 2020Master
dtay wrote:I've even sent screen video caps showing me changing the icon, say, of my Ring Doorbell which it thinks is a laptop or computer, to a ring doorbell, and but it doesn't stick.
I can confirm factory reset, reloading the app, removing and reloading the device or anything else will not correct the issue.
It is firmware BUG! Annoying but doesn't hurt anything, except we get customers complaining.
- ekhalilSep 24, 2020Master
Yes, I can confirm that I see the same issue. changing device icons -for devices added after upgrading to V3.2.16.6- is not working.
I hope that this will be fixed soon.
- BiGMERFSep 24, 2020Apprentice
happens to me to.. on my last system and my new one.. i had to reboot my new one cause my sattelite decided to just dissapear.. when it came back all the ones i changed went back
- FURRYe38Sep 24, 2020Guru - Experienced User
Be sure you make contact with NG support about this. The more users report this the better.
