Wing_Man
Sep 26, 2022Aspirant
Schedule is not function under security section into advance tab
Sechedle is not function under security section into advance tab. Any one has similar issue 😞
Sep 26, 2022Guru - Experienced User
"Sechedle" huh?
- Wing_ManSep 26, 2022Aspirant
Typo error.
It should be "Schedule is not function under security section into advance tab".
And specific device IP address is reserved to be.- FURRYe38Sep 27, 2022Guru - Experienced User
Had it been working before updating to v.11?
Wing_Man wrote:
Typo error.
And specific device IP address is reserved to be.- Wing_ManSep 27, 2022Aspirant
It is first time that I use Orbi, so I do not know that is worked or before v.11.
Any tips about the setting ?
Thanks
