Wing_Man
Sep 26, 2022Aspirant
Schedule is not function under security section into advance tab
Sechedle is not function under security section into advance tab. Any one has similar issue 😞
iyang
Oct 19, 2022NETGEAR Expert
Hi Wing_Man ,
Can you provide Orbi's model name ?
And what's setting do you use in schedules function ?
Thanks.
Wing_Man
Oct 19, 2022Aspirant
Orbi Model is RBR752.
Schedule Setting: Days Block - Everyday; Start: 00:01 End: 07:01
- iyangOct 19, 2022NETGEAR Expert
Hi Wing_Man ,
Do you try to set "Block Sites"/ "Block Services" and choose "Per schedules" ?
You need to set "Block Sites"/ "Block Services" and "schedules", and then it should work.
Thanks.
- Wing_ManOct 20, 2022Aspirant
For your information that I have already set Block Services and choose Per schedules.
However, it is not worked in 3 versions (4.6.8.5,4.6.9.11 ,4.6.11.1). That's why I would like to seek expert to advise
Many thanks.- FURRYe38Oct 20, 2022Guru - Experienced User
FYI, this has been passed to NG for review. NG will need to review and fix this issue as it seems to be a bug. There is nothing else we can do here in the forums to correct it. Users will need to be patient.
