rj1031
Aug 12, 2020Aspirant
Security camera can't connect to Orbi AX6000
I recently installed an Orbi AX6000 (RBR850). As soon as I installed it, my outdoor (alarm.com) security camera stopped working. I called the security company (Safehaven-ADT dealer) and requested for...
- Aug 24, 2020
End result...
I had to take the Orbi satellite closer to the camera (inside the garage) in able for it to connect. It's strange how Spectrum's router can easily connect from the same position where the main Orbi is located. I feel like I got robbed spending a lot of money and it didn't perform according to its spec/design.
Neverthess, I appreciate your help!
Aug 13, 2020Guru - Experienced User
Is this a 2.4Ghz camera or dual band?
"He moved the camera closer by 6 feet and the camera worked." So it works near the RBR and doesn't connect at a distance?
Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
try changing CTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
rj1031
Aug 14, 2020Aspirant
"What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected."
The distance is within 30 feet.
"Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
try changing CTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings"
I will try these settings and let you know.
Thanks for your help!
