rj1031
Aug 12, 2020Aspirant
Security camera can't connect to Orbi AX6000
I recently installed an Orbi AX6000 (RBR850). As soon as I installed it, my outdoor (alarm.com) security camera stopped working. I called the security company (Safehaven-ADT dealer) and requested for...
- Aug 24, 2020
End result...
I had to take the Orbi satellite closer to the camera (inside the garage) in able for it to connect. It's strange how Spectrum's router can easily connect from the same position where the main Orbi is located. I feel like I got robbed spending a lot of money and it didn't perform according to its spec/design.
Neverthess, I appreciate your help!
Aug 17, 2020Guru - Experienced User
You can play around with these settings as well. Try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
rj1031
Aug 24, 2020Aspirant
End result...
