rj1031
Aug 13, 2020Aspirant
Security camera can't connect to Orbi AX6000
I recently installed an Orbi AX6000 (RBR850). As soon as I installed it, my outdoor (alarm.com) security camera stopped working. I called the security company (Safehaven-ADT dealer) and requested for...
- Aug 24, 2020
End result...
I had to take the Orbi satellite closer to the camera (inside the garage) in able for it to connect. It's strange how Spectrum's router can easily connect from the same position where the main Orbi is located. I feel like I got robbed spending a lot of money and it didn't perform according to its spec/design.
Neverthess, I appreciate your help!
rj1031
Aug 24, 2020Aspirant
End result...
Aug 24, 2020Guru - Experienced User
Placement and distance is key to any wifi configuration. Different HW does different things and may not work the same as other HW devices.
Glad you got it working.
Enjoy.
