AllDueRespect
Aug 21, 2020Initiate
SECURITY KEYWORDS BLOCKING not working as per manual
Good day, A bit frustrated these advertised features shown in manual for RBR750/RBS750 are not working. (unable to find drop-down model for reference but is WiFi mesh Kit RBK752, 1 router, 2 access ...
jk4peace
Sep 11, 2020Aspirant
Hi, I have the exact same problem. I just purchased AX4200 Orbi Tri-band mesh wifi 6 system from Costco for $450 and used the keyword blocking feature but it is hit and miss. The sytem allows most block sites to go through. It is completely useless. I also tried setting up webcontent filtering using OpenDNS (it is free and it worked well with my TP-Link router) but it is not working on Orbi :p(. I am researching OpenDNS forum to figure out a way to get it to work on Netgear Router Orbi. Good luck
BiGMERF
Sep 12, 2020Apprentice
yea i got to agree.. for such a high priced item to not have a basic feature like for instance having access from my sons xbox turn off and on at a certain time is rediculous and really has me thinking of bringing mines back.. i mena you get that type of feature free on routers and mesh systems that are a fraction of the cost
