dlange
Aug 12, 2021Aspirant
Selecting higher channels via Telnet on Orbi RBR850
Referencing a-brittis original / closed thread here. Suggesting the following telnet commands to change the channels used: // Enable telnet access on your router
http://192.168.1.1/debug.htm
chec...
Indths2register
Aug 25, 2021Aspirant
The commands your looking for one logged in via terminal are the following:
nvram show
Displays current configuration
nvram set (config item) (setting)
Sets the function/feature to the option selected
nvram commit
Saves to memory to survive a reboot
If you downgraded to enable telnet verify you have it in the nvram show and do an nvram commit to ensure it survives past reboot or firmware upgrade.
nvram show
nvram commit
