MingusTheBugg
Sep 16, 2020Aspirant
Selling a Satellite? ax4200 RBR750
Hi, I bought an Orbi Router and 2 Satellite system. I have a small house, and it was probably overkill. I only need one router and 1 Satellite. Would I have any issue breaking up the pair o...
Mstrbig
Sep 16, 2020Master
As long as your friend has an AX system you will both be good. Currently, Orbi WiFi 6 Systems are only compatible with Orbi WiFi 6 satellites.
- MingusTheBuggSep 16, 2020AspirantThank you. That makes sense. It must be the same Wifi 6 version, but as long as that requirement is met, we should be good.
I’ll check with my buddy just to make sure.
Thanks!- FURRYe38Sep 16, 2020Guru - Experienced User
Please post about any Orbi AX questoions or information over in the Orbi AX Forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Enjoy.
