donawalt
Nov 05, 2022Mentor - Experienced User
Sending logs by email not working for me
I have not gotten an email of the log for a long time. Today I noticed 2 error entries about 3 hours ago: [Internet disconnected] Saturday, Nov 05,2022 15:46:24 [email failed] -5.7.9 Application-sp...
TC_in_Montana
Nov 07, 2022Virtuoso
Are you using your regular GMail password or did you set up a 2FA password? To be able to use GMAIL for sending logs, you need to follow the instructions here: https://www.windowscentral.com/how-set-two-factor-authentication-2fa-gmail-outlook to set up the 2FA password, then use that password in the setup.
You will need to use port 587 and requires authentication... provide your gmail address and the 2FA password that Google provided when you followed the setup link noted above.
donawalt
Nov 07, 2022Mentor - Experienced User
Hi TC_in_Montana , thanks - I Had 587 originally, I'll go back to it. I do have an App password, which Google says is for apps that can't handle 2FA:
The link you sent was a little different for Outlook than what I am doing as far as I can tell, but I should have it correct.
- FURRYe38Nov 07, 2022Guru - Experienced User
If you can't get email logging working again just disable it. Logging fix hasn't come thru nor has been fully addressed, even on the 9 series so I turn off email logging and even Local logging has been disabled as well. I recommend not using it until NG can address these issues and fix them.
- donawaltNov 07, 2022Mentor - Experienced User
I did disable it. TC_in_Montana tried about 100 things and it did not work.
What happens when the log fills (or should I say what is SUPPOSED to happen) if there is no email - should it just clear the log?
- CrimpOnNov 07, 2022Guru - Experienced User
The Orbi log is a "rolling" type of log. When it fills available space, the oldest entry is deleted every time a new entry is added.
