toybuilder
May 20, 2023Follower
Sengled LED bulbs stopped working; can no longer get on network
I had a Sengled WiFi color LED light bulb at home which had been working for more than a year. A couple months ago, that bulb stopped working. After I was unable to successfully reset and re-pair t...
CrimpOn
May 20, 2023Guru - Experienced User
If this is the bulb, Amazon says I can have it May 21:
Happy to try it on a couple of Orbi systems and see what happens.
- CrimpOnMay 22, 2023Guru - Experienced User
(That was NOT the correct bulb. "My Bad" for not reading carefully.)
Amazon just delivered a pair of sengled W31-N15 color bulbs. Works with Orbi!
- App download and setup is ordinary.
- Smartphone was connected to Orbi at 5G. (Yes, the instructions prattle on about "must be connected to 2.4G WiFi", but that was not the case.)
- Did not elect to control bulb with Alexa or Google.
- Added one bulb following instructions. No problem. The app found the bulb. Not the quickest I've seen, but it did find it.
- Fairly tedious process of defining the "Room" and putting bulb into room. Found the app really confusing. It kept saying I was attempting to cancel the setup when all I wanted to do was see it turn on and off.
- Found defining the color especially frustrating.
- Anyway, color is set. Turns on and off with app.
- Phone remains connected at 5G.
If one of these has quit working, it may have failed.
