jfer3351
Aug 12, 2023Aspirant
Separate IoT WiFi network available in Orbi RBK853?
Dear Netgear community, Does the Orbi RBK853 provide a separate IoT WiFi network operating exclusively in the 2.4 GHz band? The RBK853 user manual suggests that a separate IoT WiFi network in th...
- Aug 12, 2023
Not at this time. FYI, be on the look out for next FW update. All I can say.
Aug 12, 2023Guru - Experienced User
jfer3351
Many thanks for the quick answer!
Any idea about the release date for this FW update? I need a dedicated IoT network in the 2.4 GHz band rather urgently and, at the moment, my only option in the Orbi ecosystem is the pricey RBKE963.
Thank you.
Thank you.
