jfer3351
Aug 12, 2023Aspirant
Separate IoT WiFi network available in Orbi RBK853?
Dear Netgear community, Does the Orbi RBK853 provide a separate IoT WiFi network operating exclusively in the 2.4 GHz band? The RBK853 user manual suggests that a separate IoT WiFi network in th...
- Aug 12, 2023
Not at this time. FYI, be on the look out for next FW update. All I can say.
jfer3351
Many thanks for the quick answer!
Any idea about the release date for this FW update? I need a dedicated IoT network in the 2.4 GHz band rather urgently and, at the moment, my only option in the Orbi ecosystem is the pricey RBKE963.
Thank you.
Thank you.
Aug 12, 2023Guru - Experienced User
I don't know.
