colst03
Jun 10, 2022Tutor
Serial or Star setup for Orbi 960 Wifi 6E
Hello, Is it possible to setup the satellites in series or only in star configuration ? for example if we want to cross a long distance. thanks in advance.
- Jun 10, 2022
Yes and yes:
30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
colst03
Jun 10, 2022Tutor
Hello,
Is it possible to connect 2 Orbi 960 together using a RJ45 Cable ?
Thanks in advance.
Stephane.
Jun 10, 2022Guru - Experienced User
Yes and yes:
- colst03Jun 10, 2022TutorThanks
