wifiblues
Oct 13, 2021Luminary
service unreachable AX 4200 RBS750
hi wanted to update fw to the latest version available this week. on the orbilogin page, the manual update box lists two of three satelittes status as unreachable - it also does not list the sa...
wifiblues
will the update take if the Orbi login page does not recognize the sattelite?
Oct 13, 2021Guru - Experienced User
Is the RBS seen on the RBRs connected clients page? If they are, then use the IP address given to them to access the RBS web page and send the FW file there. Update the RBS first, then RBR lastly.
- wifibluesOct 13, 2021Luminary
the RBS IP address is listed and I plugged that number into two different browsers and it could not be reached.
- FURRYe38Oct 13, 2021Guru - Experienced User
Even if you bring the RBS 1 at a time to same room as the RBR and connect them wirelessly, you can't reach there web pages?
have not tried that - to bring each one closer to the router to reach the IP address for the satellite -
if i do a factory reset on the satellites - can i update to the latest firmware? assuming that after the reset, the satellite will be recognized.
