asmc
Mar 13, 2020Aspirant
Service unreachable
orbi 852 same problem whatever old version or latest vesion fireware
Mar 13, 2020Guru - Experienced User
Be sure to check your CTS and RTS values. If they are at 64, please change both to 2347. Reboot both RBR and wireless devices.
asmc wrote:orbi 852
