skinsy
Aug 14, 2023Follower
Set up Orbi RBK353 -Firmware Check error - there was a problem checking firmware update
Have set up and everything has gone as expected except when I reached this stage. It says try again, have done this a couple of times. If I skip, I assume my firmware is not up to date, it should be...
Aug 18, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Are you seeing this in the setup wizard or under the RBRs web page for checking if there is new FW available.
You can manually download and install FW as well:
