00Lazy
Feb 23, 2024Aspirant
Set up Orbi RBK752 router as satellite
I am new here and a noob when it comes to technology, so I hope someone here can help me. I have bought an Orbi RBK753 first and later an Orbi RBK752. First I have installed RBK753 at home and it w...
Feb 23, 2024Guru - Experienced User
the routers can't function as a satellite. You actual have to use a satellite.
the old RBR50 had some aftermarket firmware you could install to make them a satellite but I haven't seen it with the newer AX versions
00Lazy
Feb 28, 2024Aspirant
Dear Guru,
Thank you for your answer.
I have set up the router as a satellite, see attachment.
It looks like the network can see the router as a satellite.
Or is it still a router that I have tried to set up as a satellite, which won't work?
Is my conclusion correct?
- CrimpOnFeb 28, 2024Guru - Experienced User
The magenta dot indicates that the device is not connected.
It is not clear (to me) exactly what information is displayed next to the dot. With my system, for some satellites it is the "name" that I have assigned to the device and for one it is the word "Satellite".
Could you please open the web interface and look at the Attached Devices page? Does this device appear at the top of the page with the other satellites?
- FURRYe38Feb 28, 2024Guru - Experienced User
How was the RBR setup as a satellite? Did you configure AP mode?
Again, the RBR750 is not supported in RBS mode. Only in router or AP mode.
00Lazy wrote:
Dear Guru,
Thank you for your answer.I have set up the router as a satellite, see attachment.
