Pauljabez
Apr 26, 2021Aspirant
Set-up ORBI RBR850
Hi All, Today I purchased ORBI mesh system RBR852. I have a Netcomm NDD-0300 NBN modem supplied by TPG. I installed it using the APP. the wifi is working fine, but there is no internet connec...
Apr 26, 2021Guru - Experienced User
Try powering OFF the ISP ONT device and RBR for 30 seconds then back ON?
Ensure your using good quality LAN cable between the ONT and RBR. CAT6 is recommended.
Pauljabez
Apr 29, 2021Aspirant
Thank you for your reply. Netgear technical support said ORBI RBR850 will not work with Netcomm NDD-0300 FTTC NBN modem. I have to return and find some other solution.
Currently I have d-link DL-4320L modem/router which works fine, but not powerful enough for wifi signal to reach the first floor of the house. Do you have any suggestion?
- FURRYe38Apr 29, 2021Guru - Experienced User
On the D-Link modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
- KylzAug 01, 2021InitiateI have set up Orbi RBR853 on NBN FTTC with same NBN connection box. There is some additional configuration required, which is generally available from your ISP.
The only issue I faced similar to yours, was activating Armor. While this was activated, I experienced frequent dropouts on the internet port. Since disabling the trial, my connection has been stable.- FURRYe38Aug 01, 2021Guru - Experienced User
Thanks for posting this information. I beleive the OP returned his Orbi system though. Maybe they will come back.
The only issue I faced similar to yours, was activating Armor. While this was activated, I experienced frequent dropouts on the internet port. Since disabling the trial, my connection has been stable.- KylzAug 02, 2021Initiate
All good - I just figured I'd put in my experience, just in case others see this post.
Main thing is that it can be done, with a little configuration :)
