Pauljabez
Apr 26, 2021Aspirant
Set-up ORBI RBR850
Hi All, Today I purchased ORBI mesh system RBR852. I have a Netcomm NDD-0300 NBN modem supplied by TPG. I installed it using the APP. the wifi is working fine, but there is no internet connec...
Aug 01, 2021Guru - Experienced User
Thanks for posting this information. I beleive the OP returned his Orbi system though. Maybe they will come back.
Kylz wrote:
I have set up Orbi RBR853 on NBN FTTC with same NBN connection box. There is some additional configuration required, which is generally available from your ISP.
The only issue I faced similar to yours, was activating Armor. While this was activated, I experienced frequent dropouts on the internet port. Since disabling the trial, my connection has been stable.
