hcaballe's avatar
hcaballe
Follower
Sep 22, 2024
Setting up 2G on RBK853
I'm trying to setup 2G on this router, I don't see a place to set that up,
  • FURRYe38's avatar
    What firmware version is loaded on the RBS and RBR?
    v7 FW has a separate IoT network that you can configured 2.4 or 5Ghz or both.
  • plemans's avatar
    Its a mesh router. by default the 2.4ghz/5ghz are both on and configured to the same ssid.
    Maybe a better description of what you're trying to do or the issue you're trying to fix might help us to help you
