AngieT053065
Oct 24, 2022Aspirant
Setting up a device that requires a 2.4Mhz band
First, let me start out by saying that I am not extremely technical but I have spent quite some time trying to get a diffuser added to my home network with no luck and need some assistance (in layman...
Oct 24, 2022Guru - Experienced User
Cheat. Power off the router and the satellites Setup a phone hotspot for 2.4ghz with the same exact ssid/password as the router.
then use a different phone to setup the diffuser. Once its setup and connected, power the hotspot off and the router on. It should auto-connect.
McLong
Oct 24, 2022Luminary
Great idea! The only thing to note here is to power off all your devices already configured on the same network so they don't auto reconnect to the mobile hotspot as it supports a limited number of devices.
