gpatterson
Jul 15, 2020Aspirant
Setting up an Orbi AX6000 (RBK853)
I have recently purchased an AX6000 three pack and I am awating delivery. I have a question about set up. I have house that is four levels which is about 6,000 square feet. Currently my modem is on...
- Jul 15, 2020
it needs to go:
modem----->router-------->switch/satellites.
And its best to centrally locate the router unless you plan on the satellites being hardwired in. If thats the case, then you can space them however works best for you.
Just make sure the switch comes after the router, not before.
Jul 15, 2020Guru - Experienced User
I highly recommend not putting the RBR router in the basement. Basements are not recommended places for wifi routers. Concrete and steel in the surrounding basement and foundation will impact wifi signals and cause problems. Keep the main base router on the 2nd or main floor of ths home, or higher.
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
gpatterson wrote:I have recently purchased an AX6000 three pack and I am awating delivery. I have a question about set up. I have house that is four levels which is about 6,000 square feet. Currently my modem is on the 2nd floor ( counting the basement as a 1st floor) I am thinking about moving my modem into the basement where the cable connection (RCN) comes in for the internet. My question is can I set my modem ( CM1000 ) so that I can run a switch from the modem to each ethernet port for the differnt rooms in the house and then from those ports set up the AX6000 system? Putting the AX6000 router on one floor and the satelites on different flloors. I wouild only activate the ports where I would look to set of each of the AX6000's.
