KKSigs
Apr 16, 2020Guide
Setting up New RBR850 from RBR50 with OnQ set up
So looking for suggestion for a smooth transition if possible. I just purchased a RBR850 and trying to get some suggestions on setting up my new system and transferring all my information from my Or...
Apr 16, 2020Guru - Experienced User
Unfortunately you can't apply the config file from a different model system to the newer model system.
I would do this, log into the RBR50s web page and take screen captures of all pages that seem to have configurations for WiFi and LAN and WAN and Internet sections of that router. You can even leave the RBR50 online and use a separate PC connected to the RBR850, configure the 850 manually while not connected to the modem. Go thru and get the 850 setup while looking at each page on the RBR50 to mirror it's settings on the 850.
Once you have the 850 setup and configured like the 50 router, disconnect the 50 series router and install and connect the 850 series router. be sure to power OFF the ISP modem for 1 minute then back ON. Let it sync again. Then power ON the 850 series router. You should be up and running.
- KKSigsApr 16, 2020Guide
Thanks so much! Already took screen shots.l Regarding logging into the rbr 850, with another computer directly attach to the rbr850 via ethernet and logon with the orbilogin.net and not attached to internet?
- FURRYe38Apr 16, 2020Guru - Experienced User
Correct.
- KKSigsApr 17, 2020GuideWell got everything installed and copied all settings but getting horrible download speeds and great upload speeds. Compared to my RBR 50 getting about 100-150Mb slower speeds on downloads. Notice slight buffering with streaming. I was happy with my RBR 50 but hoping that the RBR850 would be that much quicker and more for me. Wondering what I need to tweak to achieve that. However that’s hard to do when your trying to do telemedicine and kids doing e-learning through this time. Any other suggestions?
