KKSigs
Apr 16, 2020Guide
Setting up New RBR850 from RBR50 with OnQ set up
So looking for suggestion for a smooth transition if possible. I just purchased a RBR850 and trying to get some suggestions on setting up my new system and transferring all my information from my Or...
Apr 17, 2020Guru - Experienced User
Ya which for some reason orbi systems do not like that feature.
Do you have to use that particular switch or can you install in its place a different switch? Like NG GS 105 or 108 switch?
What is the connection lay out diagram look like staring from the ISP ONT/Modem then to > router> then Switch then RBS?
Please give a description of this lay out.
KKSigs
Apr 18, 2020Guide
Unable to switch out the legrand for the NG because I have to many switches and it would be costly. But from what I see and think from a diagram standpoint it goes. ATT Fiber ISP to Arris BG210 modem to ORBI router to 3 gigabit switches to every Ethernet port in the house has believe. The Orbi satellites gets directly plugged into one Ethernet port in the house.
- KKSigsApr 18, 2020Guide
Update, so I made the changes suggested, some of which were already done prior. But restarted my modem and then orbi and was getting better consistent speeds. Then proceeded to do Ethernet Backhaul, restarted modem and then orbi, now getting consistent speeds once again. So far so good. Using one of my old orbi satelites as Ethernet backhaul and working well in addition. Now just waiting for my extra RBS850 that I purchased to get better coverage for my home which is about 8000 sq. ft.
Thank you FURRYE38 for you input and suggestions
