evolving
Jul 06, 2024Follower
Setting up Nighthawk modem router with new Orbi mesh
I have an existing Nighthawk AX2700 router modem CAX30S and a new Orbi 650 Series AX3000 mesh.
How do I configure the router modem to work with the Orbi mesh? I was told I'd have to setup port forwarding.
Thanks for the help.
IF you use the CAX30 in router mode, I'd configure the Orbi system for AP mode:
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopIF you want to use the Orbi system as your main router system, set the CAX30 for modem only mode:
https://kb.netgear.com/27191/How-to-set-the-cable-modem-router-to-be-on-modem-only
1 Reply
