Pguinet's avatar
Pguinet
Follower
Oct 25, 2020
Setting Up Orbi 6 RBR750
It took awhile but I have set up my ORBI system. I renamed the network the same as my old network and all everything appeared to work. Now all computers and devices are working except for my Sirface Lap Top. I try connecting to network and it says no internet connection but all my other diverse show an internet connection and are working. Any suggestions? Tried forgetting the forgetting the network a few times. No siuccess. Any suggestions?
  • CrimpOn's avatar
    CrimpOn
    Pguinet wrote:
    It took awhile but I have set up my ORBI system. I renamed the network the same as my old network and all everything appeared to work. Now all computers and devices are working except for my Sirface Lap Top. I try connecting to network and it says no internet connection but all my other devices show an internet connection and are working. Any suggestions? Tried forgetting  the network a few times. No siuccess. Any suggestions?
    I always do as you did: give the new WiFi network the same SSID/password as the old one. (a) all devices should connect automatically and (b) if "something goes horribly wrong" I can simply unplug the new network and go back to the old one.
    You may find that people who have the new AX Orbi models are more likely to be participating in the AX community forum and may have more insight into "anything new" about them: https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    Since the problem is isolated to the Surface Laptop, I would focus troubleshooting on it, rather than the Orbi. "Forgetting" is the first thing I would have tried as well.  Another step is to distinguish between (a) connecting to the Orbi (getting an IP address) andn (b) having internet access.  The Orbi web interface, "Attached Devices" web page would indicate if the Surface is connecting, as would the DOS command:
    ipconfig /all
  • FURRYe38's avatar
