tfraser91
Dec 16, 2021Aspirant
Setting up Orbi RBK853 in Router Mode with BT FTTP
Hi All, I currently have my BT FTTP going into my BT Router and then an ethernet cable going from the BT Router to the Orbi (in AP Mode) however, I keep encountering issues with this setup and am wo...
tfraser91
I called BT this morning and they said to get in touch with NETGEAR and ask them! No-one wants to advise it would seem but I could try calling back...
Dec 16, 2021Guru - Experienced User
Why would they direct you to NG when it's THERE system and THERE HW and services. They should know if there router is needed or not. NG will not have this information.
Otherwise, Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
