JBInspired
Aug 08, 2020Follower
Setting Up Orbi RBR750 with an ATT Modem
I have a couple set-up questions for my new Orbi AX4200 (w/satellites). My ISP is AT&T. I have an Arris BGW210-700 modem. I do not have anything plugged directly into the modem for internet access. I do not have anything other than internet with AT&T.
Question 1: I have a couple things plugged into the Ethernet outlets which are using the AT&T modem for internet access. Do I need to change settings somehow to plug this directly into my router or can I still use the Ethernet through the AT&T modem? Is there a better practice?
Question 2: My modem is still broadcasting WiFi. There doesn't seem to be a bridge mode in the AT&T modem. Do I need to disable the Wi-Fi through the modem? My Modem has one WiFi network name. The Orbi router has a different WiFi network name. If so, how? And, do I need to reset my Orbi setup? I saw something about setting it up in a different format which might lose some functionality. Again, what is the best practice on this?
1 Reply
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first.
Also there is this:
